What does this connect to?
Sorry, no pic. At the rear of the engine is a round, I think 3 prong plug. But with the intake and cyl off, I see nothing to connect it to. I'm a bit stumped. No noticeable problems with the car running. Well, except for the blown head gasket and broken valve spring.
Its the Top Dead Center sensor plug most likely. Follow the cable, should go down to the bellhousing, to the clutch inspection hole.
Doesnt connect to anything, except a never used peice of test equipment. Just zip tie it to the bracket at the back of the cam tower, thats the stock spot
