Late center console armrest hinge thing that always breaks
So, when I bought my car the hinge in the center console was broken. The PO gave me a new one with the car. This was a little over two years ago maybe. Well it broke again. Instead of having to spend $20 (or whatever it costs) every couple of years, I tried using some small metal hinges from the local hardware store. They work OK, but not perfect. The side of the console with the hinges sticks up when it's closed so there is a gap, because the hinges do not sit flat with the plastic pieces, and the hinges themelves stick out a bit and are very noticable (and out of place looking). Has anyone figured out a good way to fix this issue that looks decent and won't break easily?
Originally Posted by bloodraven
take it out and replace with cupholder/change tray
Although I've looked at the other options availible, I want to keep the stock one.
Originally Posted by faithless
what kinda hinge? maybe a piano hinge is what youd rather use, you could paint it black and it would probably look uniform enough not to notice it.
