Head Gasket Problem???
Old 09-11-2005 | 03:49 AM
PCMAX's Avatar
PCMAX
Default Head Gasket Problem???
I have an oil leak from the fwd most bolt on the hea, it leaks onto the exhaust and causes quite a bit of smoking. It is already very tight, does this mean my head gasket is shot? How hard is it to replace?
Old 09-11-2005 | 12:07 PM
Granite 944's Avatar
Granite 944
looks like you need to change the cam tower gasket, if its leaking there. Not the head gasket. About a $7.00 gasket, but a fair amount of work.
Could also be a leak coming from the large o-ring in the back of camshaft front housing. Clean everything good up front, and start watching for where its coming from.
Quick Reply: Head Gasket Problem???
