Venturi delete...cycling valve..more ??'s
While doing a venturi delete, do I HAVE to delete the cycling valve...all the directions I read say that it has the cycling valve deleted....anyone?
You only need to delete the cycling valve if you are going to install a MBC or an EBC.
If you keep the cyling valve, it is a good time to replace the three hoses for a piece of mind.
