TransmissiOWNED?
Just a car guy
Originally Posted by testarossa_td
If this were a different thread R&P could stand for rack and pinion
Cute
http://www.flying-pig.co.uk/mechanis...kandpinion.swf
Cute
Anyway on the clutch subject, I went for what was behind door number one at Vertex as well. Nice kit. Comes with clutch disc, release bearing and pressure plate. All in nice, easy to carry boxes.
While in there, I did the pilot bearing in the center of the flywheel (I mean crankshaft), the bearings on the release bearing fork shaft and misc plugs and hardware.
The transaxle was a whole other story. But it made sense to do the clutch while I had the gearbox out to fix the R & P.
See the pretty pictures?....
Okay, here's the update.
Spun the tires with the clutch down, the input shaft (I assume it's under a plug, and you can see it after removal of the plug) spins, so my R&P is okie dokie?
Noise is all coming from the clutch area, so I'm pretty sure it's there
