URGENT: Speed at specific RPM in 5th
Mike asked me to see if anyone out there had a chart, or idea of how fast he would be going at a specific RPM in 5th gear for an 85.5 944na.
He is driving from Indiana with no speedo, so that would be helpful
Thanks for the help!
~Eric
~Eric
Eric, tell him to check if the plug just bounced out of the speedo sensor, its on the top of the flange for the half shaft on teh driver side of the transmission, it happens soemtimes. Unless he's already sure why it isn't working, it's worth a shot! Don't even need to jack up the car probably.
Lazer Beam Shooter
i had to do this because i had an early tranny in a later car... my only guide was that about 3000RPMs (give or take 100) youre going about 80mph
I was just thinking the engine would not be running the same as it did when it was brand new. I also know that my stock 944 may be slightly faster or slower than someone else's stock 944.
It doesn't matter if the engine isn't running as well. unless your clutch is slipping.. it can't really change, short of smaller/larger tires.
3000 rpm is 3000 rpm no matter what. if the engine is running worse it may take more gas to get 3000 rpm, or more time, whatever, but 3000 rpm will always be 3000 revolutions per minute. And, that means 3000 revolutions of the drive shaft (or at least some constant multiple), and the tranny is connecting you to a hard gear, which means a certain amount of wheel rotation per minute... how could any of this change?
Just a car guy
~Eric
~Eric
Let:
v = vehicle speed in mph
s = engine speed in rpm
gr = selected gear ratio = 0.730 (was 0.829) for 5th gear (overdrive)
fdr = final drive ratio = 3.889 (9 : 35)
tc = tire circumference in feet = 6.583' for 215/60R15 tire
c = conversion factor constant = 60 min/hr/ 5280 ft/mile = 0.01136
We have now:
v = s x (tc x c)/(gr x fdr)
s x (6.583 x 0.01136)/(0.730 x 3.889) = s x (0.0748)/2.839 = s x 0.0263
Insert any engine speed for s and multiply by 0.0263 to get approximate vehicle speed. e.g.
s = 2000 rpm, v = 52.6 mph
2500 rpm, 65.8 mph
3000 rpm, 78.9 mph
Feel free to add your own factors - such as the 'Mike Factor' (m), the loaded tire radius factor (lr) or the traveling in Indiana factor (i).
As usual, Your Mileage May Vary (the YMMV factor).
Originally Posted by silverBean
That's a cool formula Scott, but a bit off from what I get, 2k is 50, but at 3k I am at 80. It doesn't exactly add up.
We're talking about gears here. If the engine turns the input shaft to the tranny 50% faster, the wheels have no choice but to go 50% faster.
hey wait a minute guys he is talking about an N/A. An N/A is not at 80 mph at 3000rpm in 5th gear maybe a turbo is though. My N/A at 3000rpm in 5th gear is about 62mph give or take a few mph. 80 mph is like 3700 or 3800rpms.
Just a car guy
If your speedometer and/or tach are in error then that is another issue and independent to the validity of the equation.
