OPRV is stuck
#32
Wow talk about an old thread resurected. I had the head off, and took the oil cooler off, and realigned it, and put a new style valve in it, and I still have low oil pressure in that car.
Sooooo.. This is what im thinking happned with the car. I started having oil pressure problems after i replaced the timing belt and balance belt, which i took the crank gear off for. Before that my oil pressure was perfect. Now, its low. So, one would think that there was something wrong with the way I put the gears back on. Well, i took them back off, replaced the P/S pulley, made sure the washer was on correct, still nothing. Yet... putting a little extra torque on that crank bolt will show a slight increase in oil pressure. Sooooo...
Soon i will take off the pulleys and examine again. But... theres no way it was related to the relief valve. I figured that It may have just been conicendental (sp?) but i suppose its not.
Theres no way its rod bearings.. they just dont all of a sudden cause really low oil pressure, it would have been a more gradual effect.
But, in no way is the engine toast, or is the car a bad car. The car is in beatiful shape, its just been plagued with this damn oil pressure problem. Time to give her a little attention I guess. Fixing up the 951 (see just hit 200k mile thread) has been a little bit of a distraction.
I will post up for future reference if I do get the oil pressure back to normal.
-Jeff
-Jeff
#34
Originally Posted by jmporsche944
Ohh yeah, i want my freakin tool back now too adam.
#35
Jeff, I skimmed the thread but did not see mention of the O-ring that fits between the oil pump drive gear and the flat washer. Is it there? If so is it hard and brittle or still pliable?
#36
You might be on to something. I really dont recall any o-ring being in there last time i took it apart. Does anyone have a part number so I can order it, take it back apart, and throw it in. Even if i have it, it might not be a bad idea to replace it next time i take it apart.
