Mullet defined
do you have heat coming from your vent when the **** is on cold? What about bearing noise when shifting? I do on my GTO with 5700 miles. here is what the experts say. And you cant blame the UAW, this one is imported from OZ.
How come a dopey 16 year old that cant afford gas has better technical knoledge here on rennlist than people that dropped 30 large for a new car over there.
i want what i paid for. i am a crybaby.
I think we are all glad to see you are just as critical of teh GTO as you were with the 944 when you posted here more frequently.
At least it just wasn't a hatred of porsche thing.All in good fun of course.
At least you have warranty, right?
The warranty is from GM, which means "could not duplicate" is going to be the answer unless i find the TSB and explain it to the service manager. you have no idea how valuable a resource rennlist is.
But seriously, my Taurus does what you are saying. I think the "auto climate control" units are designed to either have the AC going, or outside air, heated by the engine coming in! Come to think of it, without the AC on in the 944, even when it's 70 outside, the air coming in is warmer than that...right?
Hope the new Mustang GT's aren't as lame...I likey the new Mustangs!
Now excuse me...have to go put my rear wheel back on. Just painted the rear driver side rotor hat silver!
Mark
some of the very early cars they had the torgue wrong on the flexplates, there is a tsb out for that. They had it too low.
I haven't had any major problems, just a couple little things I need to address eventually.
1. tore a small piece of weatherstripping in the passenger window last winter......window actually got stuck after rollong it down in the AM after a heavy frost.
2. It rains, I drive through a puddle I get a check engine light
3. Hard putting it in reverse when it is cold....
btw, the 2004 sap is well worth it
This comment from one of those 'tards sums up tha maturity of most of the posters on there:
JFC, someone needs to get a grip.
1. I wouldn't brag about spending $600 at a strip club.
2. It's a P-O-N-T-I-A-C. To most people it is easily mistaken for a Grand Am.
DISCLAIMER: I like the GTO, it is a cool car (although I would like it better if it were badged properly for what it is, a Holden).
http://www.alldata.com/TSB/48/044818iS.html
Automotive Recall and Technical Service Bulletin Titles for 2004 Pontiac GTO V8-5.7L VIN G.
Service Bulletins
TSB Number & Issue Date TSB Title
04-08-49-005A FEB 05 Instruments - Fuel Gauge Needle Stuck in One Position
05-06-02-001 FEB 05 Cooling System - Aluminum Radiator/Heater Core Info.
04-08-46-003A FEB 05 OnStar(R) - Unable to Connect (Alaska Vehicles)
05-08-44-005 FEB 05 Audio System - Rear Headphone Ear Pads Worn/Damaged
01-08-42-001B FEB 05 Lighting - Replacement Guidelines for Condensation
00-07-30-009A FEB 05 A/T - New/Reman A/T Identification
00-08-46-003B FEB 05 Instruments - GPS System Performance Degradation
03-09-41-003A FEB 05 Restraints - Air Bag System Diagnostics
04-07-30-013A JAN 05 A/T - Shift/Driveability Concerns/SES Lamp ON
04-08-48-001A JAN 05 A/C - Rear Defogger Heating Grid Damage Detection
03-08-44-005C JAN 05 A/C - Rear Defogger Inoperative/Radio Interference
04-06-03-016 DEC 04 Battery - Specification Label Clarification
00-07-30-022C DEC 04 A/T - 4L60/65E No Reverse/2nd or 4th Gear
01-07-30-041A DEC 04 A/T - Fluid Leak Diagnostics
04-03-10-001A NOV 04 Tires - Puncture Repair Procedures
04-08-46-003 NOV 04 OnStar(R) - Unable to Connect to OnStar (Alaska Only)
99-08-51-007B NOV 04 Wheels - Aluminum Wheel Refinishing
03-07-29-004A NOV 04 M/T - Operational Characteristics
04-03-10-013 OCT 04 Drivetrain - Rear Drive Characteristics/Winter Tires
01-01-38-006D SEP 04 A/C - R-134a System Flushing Procedures
04-07-30-037 SEP 04 A/T - Dexron® III(R) (H-Revision) Specification Upgrade
02-07-30-052C SEP 04 A/T - Fluid Flushing Procedure/Tool
00-08-48-005A SEP 04 Body - Distortion in Outer Surface of Vehicle Glass
04-05-22-001 SEP 04 Brakes - Whistle Noise With Brakes Applied When Stopped
04-08-68-002 SEP 04 Cruise Control - Increasing Set Speed
04-08-68-003 SEP 04 Cruise Control - Knock or 'Thud' Noise
04-06-03-006 SEP 04 Electrical - Proper Jump Starting Procedure
04-06-04-051A SEP 04 Fuel System - Maintenance Cleaning of Fuel Injectors
04-08-49-023 SEP 04 Instruments - Speedometer MPH Indicator Too Bright
01-07-31-002A SEP 04 M/T - Improved Hydraulic Clutch Bleeding Procedure
99-09-40-005B SEP 04 Restraint System - Seat Belt Extender Availability
01-07-30-036D SEP 04 Transmission Controls - DTC P0756 Diagnostic Tips
04-03-10-012 SEP 04 Wheels - Chrome Wheel Pitting/Brake Dust Accumulation
04-03-08-014 AUG 04 Suspension - Front Suspension Knocking Noise on Bumps
04-08-64-018 AUG 04 Body - Front Door Lock Won't Lock/Locks Intermittently
04-07-31-005 AUG 04 M/T - Clutch Pressure Plate Wear Indicator Adjustment
04-07-31-004 AUG 04 M/T - Clutch Actuator Bleeder Screw Alignment
01-07-30-010A AUG 04 A/T - Torque Converter Replacement Guideline
02-06-03-008A JUL 04 Charging System - Operational Characteristics
04-07-30-025A JUL 04 A/T - 4L60-E/-4L65E No Shift/Slipping/Fluid Leaks
00-00-89-027B JUL 04 Interior - Odor Elimination
02-06-03-010A JUL 04 Battery - Parasitic Drain
04-07-31-003 JUN 04 M/T - Loss of Clutch/Low Pedal Height/Hard to Shift
04-06-00-047 JUN 04 Fuel - Top Tier Detergent Gasoline Information
04-06-04-045 JUN 04 Instruments - Oil Life Monitoring System
04-08-52-006 JUN 04 Keyless Entry - Operating Characteristics
04-07-30-028 JUN 04 A/T - Reverse Servo Cover Seal Leak
00-06-01-026A JUN 04 Engine - New Long Block Installation Precaution
02-08-44-007A JUN 04 XM Radio/OnStar - Problems W/Cloth or Vinyl Roofs
00-03-10-002C JUN 04 Wheels - Chemical Stains on Chrome Wheels
01-07-30-030A MAY 04 A/T - 4L60-E/4L65-E Harsh 1-2 Upshift
04-06-04-036 MAY 04 Engine Controls - Reprogramming Warranty Info.
04-07-30-023 MAY 04 A/T - 4L60-E/4L65-E New Pump/Seal/Case/Service
04-08-42-008 APR 04 Lighting - Headlamp Aiming Procedure
04-02-35-007 APR 04 Steering Wheel - Paint Peeling From Spokes
04-03-09-003A APR 04 Suspension - Knock From Vehicle Rear on Launch
04-08-63-004 APR 04 Body - Engine Compartment Dirtier Than Expected
04-06-01-013 APR 04 Engine - Serpentine Drive Belt Wear Information
04-03-09-002 MAR 04 Suspension - Clunk Noise From Rear on Hard Launch
04-01-39-011 MAR 04 A/C - Refrigerant Leak at Condenser Connection
04-06-04-016 MAR 04 Engine Controls/A/C - Revised DTC Diagnostics
04-07-31-002 FEB 04 M/T - Clutch Fluid Reservoir Appears Discolored
00-06-02-006A FEB 04 Cooling System - Coolant Information
02-07-30-001A FEB 04 A/T - 4L60E and 4L65E DTC P0894/P1870 Diagnostics
04-07-30-006 FEB 04 A/T - 4L65E, 4L60E, 4L60, 200-4R Oil Pump Spring
04-08-44-002 FEB 04 Audio System - Speakers Shut-Off at High Volume
01-07-30-038B JAN 04 A/T - 4L60-E/4L65-E MIL ON/DTC P0757/Slipping
02-06-05-004A JAN 04 Emissions - Catalytic Converter Damage/Misfire Codes Set
04-01-37-001 JAN 04 A/C - Control **** Replacement Availability
04-08-58-001 JAN 04 Body - Outside Rearview Mirror Wind Noise
04-08-50-001 JAN 04 Interior - Driver/Passenger Seat Squeaks
03-08-44-023 JAN 04 Audio System - Stuck CD Removal Precaution
03-00-89-021 JUL 03 Instruments - DIC Perceived Fuel Economy Settings
