Sender/sensor sleeve
Well, we installed the sender sleeve which protects the forward sensor from picking up the electromagnetic field from the smaller 951 starter motor.
This sleeve, 944101132000, costs over $100 Canadian so it must be made of 99 44/100% kryptonite. The original sleeve is aluminum. There was a bracket too, 94410132107 which must have been for a 951 as it had 3 holes and we had to saw a part off to make it fit. To make a long story short, it works 100% as the sleeve stops the motor from firing when a piston is halfway up.
No more backfires or starter whunk.
Thank you George B.
Mike
Thank you George B.
Mike
