New shifterwith photo!
Originally Posted by Zporsche944
I convert all my cd's to MP3 atrac then put each cd in a diff folder and put it on one cd. I can hold 7-9 cd's with out losing quailty
. And I dont have to keep changing cds ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Band, MP3's quality sucks.
Originally Posted by TheStig
I got an AGLA shift boot that has an elastic of about 1/4" thick and it broke the shift boot retaining frame wh
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
And you guys are working with black leather... try using a colored leather, its like 2 - 3 times as thick. I eventually got it in. pfft.... lightweights :P
Originally Posted by yieldsign2
Umm, you must have a cd player that reads mp3's then? You certainly aren't putting 7-9 cd's in raw format in folders on one 700 or 800 mb cd....
1 Post
if you have 400GB, you can have tons of them at higher bitrates in the car...
I also have a MP3 CD player in the car, however I never use the cd function or the radio.
It just acts as the amp for THE HIVE , which will soon not even need the headunit.
back on topic
: at least put a small sheet of paper between those cd's in the tray..
does that shifter come with the insert, or do you move the stock one over to it ??
back on topic
Originally Posted by tedwright
No, it REALLY requires some elbow grease to get it over that plastic surround. I thought the same thing when I first got mine!
Is there a trick to this?? Soaking the bottom in water maybe??
And, yes, you use your old insert - it just pops right on there.
No, it has a very thin elastic, but it is just way small compared to the original. I emailed AGLA, but got no response so far. I don't think it's the right size. There is tight, and there is silly. This has to be the wrong part number. Maybe the 993's had a smaller frame? There is a "993" sticker on the inside of the boot.
I knew I wasn't crazy! Alan Gun contacted me, saying they shipped the wrong boot and ****. The 993 set has a smaller bottom opening that wont fit on a 944/968! He's sending me the right one as we speak.
