Universal O2 -proper heat shrink application?
I'm replacing the Oxygen sensor on my '83 na with the universal Bosch model because it's so much cheaper than the version with the connector. It's a one wire sensor.
Since the sensor gets its reference O2 level from the wire, how do I make sure I don't seal it up and still keep water/salt out? Bosch's directions are useless.
Here's what I'm working with:
The new sensor has a crimp connector and a bit of exposed metal before the "insulation" starts. The existing wire presumeably has two layers of "insulation" or "shield". I haven't verified this since I'm still driving the car. What do I have to cut away and should I heat shrink everything or leave part of it exposed to the elements? I'm assuming that the shrink tubing will keep air out of whatever it covers or am I mistaken?
It did come with a few pieces of heat shrink tubing. So, it should be loose enough to allow air to pass through?
Or do I have to place the tubing in a certain way to not block anything off?
That was a tough sucka to get out. Finally gave up and brought it to a mechanic. I'm not one to let others work on my cars but without a lift and proper torch, it wasn't going to come out. I figured if they snapped the bung off, they could reweld it whereas I'd have a dead car in my garage.
I shattered a socket extension trying to get it off. Might have been the original 1983 sensor.
A lot of heat and liquid wrench later, the new sensor is in. Seems to be working well. Hopefully the heat shrink won't interfere with the readings. I know it shouldn't but I wish Bosch would have written clear instructions.
Now to get an emissions retest...
Originally Posted by Stan944
Too late now, but if you need to do remove it again, the trick is to do it on hot exhaust.
