My front end is creaking!
No, no, no... I placed the jack under the engine ONLY to install the KLA parts shown in the post. They require removal of one of th cross-member bolts on each side, so the jack was just there to make sure nothing moved and make me feel better laying underneath it.
Sway bar itself does not require engine support or clearance.
I will be under my car later this morning, but the hot set-up from memory is:
- Ramp front of car (I use those black "Rhino" ramps)
- Remove undertray
- Disconnect sway-bar ends from A-arms
- Disconnect sway-bar supports (where the rubber wrap-around bushings are)
- Fit new bushings
- Reinstall same way
A pair of vice-grips to hold the sway-bar bushing holders together while you try to line up the bolts is pretty handy.
When I got my 968, there had been a PS fluid leak that just TRASHED the bushing on that side (passenger), the ball-joint in the A-arm, and the castor block.
The only rubber left in my front end now is the two bushings that wrap around the front swaybar. All else is spherical bearing or solid (read race car). Creaking front and rear suspension is now given for me, but it shouldn't be for you.
- Remove undertray
- Fit new bushings
Probably the middle, usually it is the passenger side one that gets whacked from PS (ATF) Fluid and oil leaks. It is rare that the end ones need replacing. I would buy both middle ones and do them at the same time.
I'd say, may as well replace them all including the upper and lower bushings to the A-Arm that fasten the sway to it. Rubber gets old. You need to take all that stuff off anyway to get to the middle strap bushings and they are fairly cheap to get the whole works. I think I got them all for something like 50 or 60 bucks from Zim's.
I have the same squeak (bed springs) and it seems to come from small bumps and upon depressing the brake pedal (again, a small weight transfer). New rotors, bearing, pads, sway bar bushings, shocks/struts in past three years so they aren't worn. What lubricant can I use on the bushings to see if that's the problem? WD-40, Belt dressing?
Jim 1987 944S
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Jim 1987 944S
Jim 1987 944S![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Jim 1987 944S
Is it possible to open the center bushing clamp, cut out the stock rubber one piece bushing, replace it with the two piece delrin bushing, close it back up...all without taking the sway bar off the A-arm??
You probably can, but I imagine you'll mangle the bracket in the process.
My delrin bushings started creaking recently.
My creaking may be the result of using antiseize on them (a nono apparently), though.
I'm lame! I am JUST NOW ordering new sway bar bushings for the front.
Should I stick with stock, or get the delrin middle bushings (mainly to make it easier to get them onto the bar)? If the delrin make the car harder-riding, forget it! Also, where should I buy the complete front set?
Thanks!
Thanks!
