Which numbers on the DME matter?
I was selling the DME from my parts car, then i realized something.. I believe they should be both using the same DME, especially since I'm taking the engine out of that car.. i see 3 different numbers here. Is 078 the only one that matters? because thats the only on ethat is the same...
1, mine
2 parts car
1, mine
2 parts car
Well, which are which for. Shouldn't all 1985.5+ to 88 be the same? Both cars are 1985.5.. as far as I knew, mine was using the late electronics but with an early engine. I had a late afm on as well.
Here's what PET says...
Notice that mine looks as if it is correct for 85.5-87. Then there are a couple others for 88. Notice the one that is from my parts car, has no year designation... What gives?
What? That doesn't make any sense, this parts car was supposedly a daily driver. Didn't look like the DME area was accessed in a long while.. can you use the 944S dme with a 944 without problems?
FWIW, and not sure if it applies to your DME: There was a very early production run (beginning around January 85)o f 85.5s that used a unique DME. My old 85.5 used this version of Motronic. It used an EPROM just like the later cars.
PS i will be running an FRWILK chip, it makes any difference.
FWIW.. I think i figured that they are the same.. I just searched the part number on google.. and here is what i found on a is it a lemon.com .. interesting info...
944 1983-85/1 Control Unit, DME No Longer Available
Engine Types: 944 618 111 01 Bosch 0 261 200 015
M 44.02/04
944, 924S 1985/2-87 Control Unit, DME 944 618 121 DX
Engine Types: 944 618 121 02 Bosch 0 261 200 058
M 44.05/06/07/08 944 618 121 04 Bosch 0 261 200 077
944, 924S 1988 Control Unit, DME 944 618 121 EX
Engine Types: 944 618 121 05 Bosch 0 261 200 086
M 44.09/10
944S 1987-88 Control Unit, DME 944 618 124 AX
Engine Type: 944 618 124 00 Bosch 0 261 200 080
M 44.40 944 618 124 01 Bosch 0 261 200 187
944S/S2 1989-90 Control Unit, DME 944 618 124 BX
Engine Type: 944 618 124 02 Bosch 0 261 200 195
M 44.41
944T 1986-87 Control Unit, DME 951 618 121 BX
Engine Type 951 618 121 02 Bosch 0 261 200 075
M 44.51 (greybeige number label)
944T 1986-88 Contol Unit, KLR 951 618 113 BX
Engine Type 951 618 113 00 Bosch 0 261 201 014
M 44.51 951 618 113 02 Bosch 0 261 201 015
If you notice this part in the beginning...
Notice it has both of my DME's listed.. I'm not sure what this means though.
M 44.02/04
M 44.09/10
M 44.41
Rest in Peace
The differences may be as subtle as different fuel curves or a change in ignition advance...
Look up a guy named John Speaks (in England, he rebuilds 928 LH boxes) he may be able to decipher the bosch #'s. His email is jdsporsche@ntlworld.com.
Scott
Scott
thanks.. most of all i'd like to know which i should put in my car.. as in which is better, or is preferred. Anyone?
Maybe shooting FRwilk an email will help
