t fitting vacuum line help
I ripped the t-fitting by the fuel rail that attaches both the vacuumlines from the bypass valve and the intake manifold (see pic - I have an 86, this pic is for 89 but is the same part). I tried to purchase a t-fitting from the local auto parts store, but the bypass valve line and from the intake manifold are different IDs and the smaller line keeps blowing out.
I know the best suggesstion is to replace all the vacuum lines. Unfortunately, work doesn't give me enough time these days to spend a whole day taking the intake manifold off and doing the replacement. Anyone know the porsche part # for the circled part below - I can't find it in my version of PET? Alternatively, has anyone found a way to use a brass T fitting - I think the only way may be to add a larger ID line with zipties to the smaller line from the intake manifold. Suggestions??? Thanks -
Jeremy
Jeremy
