FS: Complete plug and play MSD
Old 07-24-2005 | 02:18 AM
TRWright's Avatar
TRWright
Default FS: Complete plug and play MSD
XP from the turbo section:
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/216910-goodies-for-sale.html
I bought this from Special Tool and never installed it. (I am going a different route.)
Originally Posted by Special Tool
This is a COMPLETELTY plug and play MSD 6AL (built in rev limit) and blaster 2 coil. All parts have less than 300 miles. Kit comes with adapted wire harness absolutely custom made for a 944. All connection are properly soldered and shrink-tubed.
All you have to splice is your existing coil wires to the signal to MSD - TWO wires - that's it. The harness passes through the existing grommet at firewall.
Blaster 2 coil comes with proper rubber sleeve to make it fit in factory coil clamp.
My 438/437 MUSTANG dyno runs were made with this rig.
The built in rev limiters mean you can set a 4k rev limit on a switch for launches. . . .or even go as far as putting it on a clutch switch to do flat footed shifting.
This would make a nice upgrade for both N/A and turbo.
$200 plus shipping, firm.
Old 07-26-2005 | 03:18 PM
TRWright's Avatar
TRWright
bump
Old 10-27-2005 | 07:06 AM
shortyboy's Avatar
shortyboy
well,i couldnt pm because box is full.so is this till for sale?thanx
Quick Reply: FS: Complete plug and play MSD
