A/C Hose Diagram
http://edge.no-ip.com/index.php?d=my...une17-acdelete
Youll have to click through them, but theres a ton of pics in there.
I'm just thinking about how the lines are laid out in my car... One of the lines is run underneath the brake booster but I don't see those lines in the diagram and photos you two posted.
The reason I'm asking is because I have to replace the lines that one of the previous owners cut
Any ideas?
Any ideas?
There are no lines that I know of that run under the brake booster. Lines 23 and 35 run along the top inside of the left fender to the firewall and then along the firewall to the right until they go into the cabin through the firewall. The only other lines are those to/from the condenser.
Any ideas?
Any ideas?
Very interesting!
There is definitely a high-pressure line of some sort under the break booster that is cut. I'm not sure where it's from! I'm going out now to take some pics. I'll be right back
Thanks again.
Thanks again.
Pictures
Okay! I had a chance to take some photos:
For the first picture, I wanted to show the location of the two high pressure lines in relation to the rest of the engine bay.
In this second picture, you can see that the two high pressure lines fork out. The larger of the two turns downward under the booster, and the smaller line goes over the booster.
This shot shows the high pressure line in relation to the brake booster.
Close-up.
Close-up.
Okie dokie, one of those is a LOW pressure line. The one that goes under the brake booster has been modified or replaced with something different. They should both run along the driver's strut tower.
I believe the larger of the two (the one under the booster) is the low pressure line.
Edit: Oh, I understand why you mentioned the "Low Pressure" line... I was just calling them both high-pressure lines to make it simpler
