944S vs. 944
Old 07-16-2005 | 08:45 PM
snyper238's Avatar
snyper238
Default 944S vs. 944
I was wondering what the difference is between the 944S engine and the 944. I thought it was just twin cam but i wasnt sure what any other diffs were.
Also whats the difference between the S engine and the S2
The reason i ask is i was wondering if it was possible to just get a 16 valve head and put it on my NA
86 944NA
Old 07-16-2005 | 08:51 PM
sharky47's Avatar
sharky47
Set to Full-Auto
Not worth it....
Other than the block and crank, the engine is different. The transmission has slightly different ratios as well, DME is different too.
Old 07-16-2005 | 08:55 PM
snyper238's Avatar
snyper238
So the pistons intake exhaust everything is different.
what are you doing with your S
Old 07-16-2005 | 08:58 PM
sharky47's Avatar
sharky47
Set to Full-Auto
Yes, pistons have cuts to clear the valves, intake and airbox are TOTALLY different, not sure about the exhaust - maybe the same.
I am turning it into a track car - I have a nice stock 944 for cruising around now and the "S" would require major money to make showable.
Old 07-16-2005 | 11:40 PM
Campeck's Avatar
Campeck
Campeck Rulez
not worth it!?
whats that based on? I was planning on doing this before my turbo idea popped up.
differences: intake, exhaust, and piston have extra notch. if your good with custom making stuff...making flanges for the S head and then just putting a normal na intake onto those flanges wouldnt be too hard.
pistons.....are you doing an engine rebuild soon? if your going to change the head the pistons arent to hard to remove and replace after that. it would be AWESOME if you did this. and i would definatly like too know power differences ect. if ppl get all pissy just shoot me a pm though.
Old 07-16-2005 | 11:46 PM
Jfrahm's Avatar
Jfrahm
I wonder if the S tranny is stronger? I have not heard of failures, and the NA trans does seem to fail with just the 150HP.
-Joel.
Old 07-16-2005 | 11:48 PM
Campeck's Avatar
Campeck
Campeck Rulez
btw. differences between the S and S2:
S= 16 V 2.5L
S2= 16 V 3.0L
Old 07-17-2005 | 01:07 AM
baldheadracing's Avatar
baldheadracing
Anything is possible, all it takes is money! :-)
The main issues would be, besides those already listed, different wiring, and a different (stronger) transaxle/ring&pinion. Then there are numerous minor things like a different belt drive for the cam. Note the S trans is based on the turbo trans (without the oil cooler). There is relatively little difference between the S and S2 trans, though.
Besides the obvious bore differences, the major difference between the S and S2 motors is the block's design - the S2 block manages the airflow between the pistons. As with the transaxle, there are tons of detail differences, of course.
Old 07-17-2005 | 01:10 AM
Campeck's Avatar
Campeck
Campeck Rulez
an s head went on ebay a while back for EVERYTHING at about 170$ i think. i was going to buy it now...and someone did 5 sec before i did!!!!
Old 07-17-2005 | 02:07 AM
MTM's Avatar
MTM
S= 16 V 2.5L
S2= 16 V 3.0L
Also the S2 also has the same body style and brakes as a regular 951, and it has the same sway bars as a Turbo S, but the springs and torsion bars are in between the 951 and the 951S in terms of spring rate. I know the S2 gear ratios are not the same as a 951, but I'm not sure how they compare to the S.
Old 07-17-2005 | 02:11 AM
Campeck's Avatar
Campeck
Campeck Rulez
yup. also has a very weird intake manifold and three bolt exhaust flanges.
the cylinders are all connected together. and the head/block have different water passages.
Old 07-17-2005 | 02:47 AM
J Chen's Avatar
J Chen
Hey Campeck,
The guy who bought the S head is real lucky.
The going rate is anywhere from 800-1200
on a good conditon head.
Old 07-17-2005 | 02:58 AM
Campeck's Avatar
Campeck
Campeck Rulez
i know! And i was so close!
Old 07-17-2005 | 05:39 AM
snyper238's Avatar
snyper238
Ok cool. But after talking to shark i think i might try a 968 swap. Of course this is all gunna be decided with money and availability.
Old 07-17-2005 | 08:58 AM
special tool's Avatar
special tool
The S transaxle is nothing like the S2. The S2 has stronger 1st and 2nd and R&P like the turbo - the S does not.
I am using an S2 LSD trans in my 575 HP turbo right now and an S LSD trans in my 924S. If I put the S into my turbo, it would last a few accels before blowing apart.
Also - you can get a chip from Vitesse to use your 944 DME to run an S head - no big problem there.
You need exhaust and intake mani because the S head uses 3 bolt flanges.
Quick Reply: 944S vs. 944
