Can you test spark plug wires with a multimeter?
I am woindering if I have a bad plug wire. Is testing the resistance from one end to the other the way to check these?
You can set teh meter to continuity and check it's continuity. Many times spark plug wires are flaky, and not completely dead. So finding a one time check may not do any good... its generally a wavering or faulty issue with spark plug wires. Although checking continuity would at least tell you if it's completely dead.
No, not very well.
If their age or condition is suspect, replace.
I suggest magnacore from www.apexperformance.com (about 60 bucks)
Some prefer other more 944 specific (expensive) wires but I don't have the energy to discuss.
MW
No, not very well.
MW
2 year old magnecor's are on there but I have revoved them at least 5 times in the last two years and when I tried to pry up the plastic part attached to one of the spark plugs I heard a crack.
sorry wrong link, try this
http://www.apexperformance.net/cartg...t.asp?scat=244
or call 866 505 2739
they might jus sell you the one you need??
good Luck
Might you have cracked the plug.
I did a few weeks ago on a mower.
MW
good Luck
MW
