Ignition key fits in but does NOT turn
Hey guys, just went to go to my final exam today...put the key I used all yesterday to drive my 85 944 in...and it doenst turn! No matter what I do. Move the steering wheel, spray wd40..etc..what do you guys suggest?
thanks
mike
thanks
mike
While I've not experienced this on a Porsche,so have no specific insight with Porsche ignition locks, this sounds exactly like what happened with my BMW. The lock cylinder jammed and would not turn because a small bit of metal broke and fouled the innards of the steering lock, which is a separate part. Dis-assembly and removal of this small metal pin cured the problem. Just to be safe, I replaced the lock cylinder too, as it was old and worn. For the Bimmer, a new lock cylinder already set to accept my old key cost $58. Again, I do not know if this applies to Porsche, but may be a good place to start.
If its a new key or a copy it may be just a hair too long, especially when its stinken hot as it could have expanded just enough. Happen to me about a month ago. A "better" locksmith cut a new key and its fixed.
