XP: Correct rear main seal?
I picked this up today, but not sure if it is the correct seal. The guy said it was, but who knows. It says on the sticker:
"99911342641
FLYWHEEL SEAL
911 911T 78+"
I tried to take a pic, but I am at my parent's and their camera is circa 1995, and wont take a pic close up enough to see it. Anyone know if this is the correct part for the rear main?
TIA
"99911342641
FLYWHEEL SEAL
911 911T 78+"
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
the rear main seal apparently works for both the 944 and several 911 models as well.
see this thread for a pic:
https://rennlist.com/forums/showthre...&highlight=pvc
Steve and Joseph, thanks a lot. The guy said it was the "better one." He also tried to sell me a 2.7 turbo engine he built years ago. I asked if he had a throw out bearing, bc I don't think they replaced it when the clutch was done last year, and he told me: "I don't stock any clutch parts for those cars anymore, peole just aren't fixing them anymore." I was like ok thanks, bye! lol
Is there anythign I should look out for while swapping this?
yea, are you pulling the engine?
either way - engine in or out - make sure to clean the seal surface well, lube the seal with some oil or assembly lube, and make sure it is seated all the way. i learned that the hard way, as you can read from my post in the link. the PVC cap works great at seating the seal.
