Nose panel interchangability
Will an 85.5+ nose panel (an 86) work on an 84? I understand the way these are mounted to the body are a bit different. The early panels are spot welded whereas the later are screwed. Will there be any problems during a swap?
Hey;
A welded early nose will go on a late car, and visa-versa. Of course the screw holes on top have to be drilled to hold it on in the later style.
EVERYTHING about a Turbo/S2 nose IS different except the hood. If you have any part of one on any other model, you have funny gaps. The profile is very slightly different.
