Rear Wheel Hub needed desperately
I went to replace the rear wheel bearings on my 968 only to discover that the hub had decided to spin on the bearing at some point in time. Consequently, the hub is trashed and will need to be replaced too. Interestingly, the bearing itself did not appear damaged which makes me wonder if the bearing had been replaced once before and the hub was damaged before the last bearing.
Anyways the part I need is a rear wheel hub- p/n 944 331 067 01. I have a '94 968 but I believe late-944s and 968s all use the same hub. I am in a time crunch as I am borrowing my companies development area to do the work. I will pay for overnight shipping and I would prefer to buy it from one of you guys rather than getting raped by a boneyard. Please email if you have one available and let me know how much you want.
Thanks,
Brett
(EDIT: Still waiting for my Rennlist Membership status to be updated...)
Thanks,
Brett
Hey Man
Too bad it's a late, I've got both rear 951 hubs/drives for an early offset I've decided to sell. Hope you find what you are looking for, it's out there and I'm sure a parter here will respond.
Looks like I need the stub axle too- p/n 951 332 235 35. This is the part with the splined shaft on one side that bolts to the drivaxle on the other. A small portion of this part sits on the bearing and it is out of tolerance as well. Hopefully someone will have some spares handy. If so, please contact me!
Thanks,
Brett
Thanks,
Brett
BUmp for Brett, all I had was a M030 set.
There is a couple on ebay that I sent him the links for, but surely someone here has these lying around.
Todd?
Todd?
Thanks guys, I found the parts at partsheaven and they gave me a fair price. First dismantler I called wanted twice as much which made me a bit nervous but partsheaven hooked me up.
Brett
Brett
