Stymied - HELP! UPDATE - Thanx Brandon!
Jane Bond 007
I went to JCWhitney to get a clutch pilot tool and they're out! Farm & Fleet and AutoZone looked at me like I was nuts and didn't even know what I was talking about. A pilot tool is all I need to get this %#@&ing engine in and now I'm stuck. ANy ideas? I have a grenaded N/A tranny; how hard would it be to take the shaft out of it? Please help out, I want that engine in before dark!!!!!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Hey Man
The broom handle or the right sized wooden dowel will get you close enough. Another thing that helps if you do end up being a bit off and the pilot bearing won't line up with the tip, have someone press the clutch in as you wiggle the shaft until it seats, it works 95% of the time.
If you go to autozone with your old clutch disk and your old pilot bearing, you can match up their pilot shafts with your stuff. I think that I ended up with a mazda pilot shaft tool to work on a 944 once.
gb
gb
For future reference, Lisle makes a "universal" tool. I forgot to order and alignment tool for a BMW 3 series clutch I replaced a couple of weeks ago. I remembered I had one of these, dug it up from deep storage. I worked great.
