Suspension top mounts.???
Hi Folks
Im in need of new bearings in the suspension top mounts .. Front...944S2 91MY.
Does anybody know where i maybee able to source a pair from...
OR
Has anybody ever done this job.....
Ive managed to get them removed but i cant seem to find any shop that will stock them....
I dont realy want to replace the whole top mount as they are a whole heap of money....
OR
I think you folks have got the wrong end of the stick..
I dont realy want to replace the top mounts JUST the bearings....
The mounts i have are the "green dot" type as fitted to a 951 "stiffer rubber"...
It seems a waste to chuck out the rubber mounts just because the bearing has failed...
I have pressed the bearing out , so all i need to do is press a new one in... IF i can get hold of some.....
In that case, get all the measurements and take a look at www.mcmaster.com
A generic bearing should fit without a problem.
