Another 944 To Spec Racing
Originally Posted by M758
David,
Welcome to show!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Serge,
You may want to consider 944-spec prep rules when you are building. 944-spec is growing in Nor-Cal and it would suck to do some to the car that makes hard to spec legalize if you wanted to go racing with it or needed to sell.
Welcome to show!
Serge,
This is funny -I just looked at your spec page and guess what? I'm using the same 350# Ground control/30mm rear torsion bar combo. On top of that, welt sways. I'll be going for blistein HDs though.
If you could send me some spec sheets, which aren't posted online, I'd greatly appreciate it.
Also, the only things I'll be selling are maybe the door panels, and all the mechanical stuff. Overall, my interior is not pretty to look at. Buy somewhere else.
-Sergey
If any one has 1 screw to go in the inside door handle, I'd appreciate it (for Pcar2). The rest can be found at Parts Heaven. I'll post some pics of what my car (Pcar1) loos like, interior-wise. I kinda like the raw, functioanl bare metal.
Simple rules for 944-Spec? Make it light (per regs), don't change any external bodywork, mod the suspension (but don't remove t-bars + no coil-overs in the back), get some Toyo 225/50s, get helmet, go racing! My racer will be shaping up - at some point.
Lazer Beam Shooter
Hey deni that screw that holds the door handle trim on can be found at home depot. I found an EXACT replacement chilling in the home depot screw department.
