Alternator out......i think i found the problem (pics)
Old 06-03-2005 | 07:03 AM
hosrom_951's Avatar
hosrom_951
UAE Rennlist Ambassador
Default Alternator out......i think i found the problem (pics)
Got the alternator out, thanks to the 17" breaker bar i got from ACE Hardware
This is what it looks like (out of the car):
I removed the voltage regulator...........:
It is worn down.......brushed are shot!
Compared to a new reguator:
I have a rebuilt alternator ready to go (thanks Ian 944online.com), i purchased that alternator 3 years ago, never installed it on the NA. Now, i need it
I COULD just replace the regulator, hope for the best....but NO. A new alternaot and voltage regulator are going in. It had to remove the coolant crossover pipe, 3-4 turbocharger coolant hoses JUST to get enough room to work on the car.
Old 06-03-2005 | 07:19 AM
951Porschiste's Avatar
951Porschiste
Here's what I used last year when I took out the alternator to do the Iceshark kit: Nice big smack with a hammer (Them bolts are real tight!)
Old 06-03-2005 | 09:05 AM
shortyboy's Avatar
shortyboy
pb blast and let it sit for a while should do it.....but yea a 17" breaker should do it
Old 06-03-2005 | 09:27 AM
hosrom_951's Avatar
hosrom_951
Andre: I see you removed the coolant cross over pipe??
Shortboy: Well.........the bottom bolt has a nut that holds it.........i just heated it up a little and used the breaker bar didn't find any PB blaster here locally, so some WD-40 was in order
Old 06-03-2005 | 06:09 PM
Danno's Avatar
Danno
Good job Hussam! FWIW, if anyone needs to have extra clearance for big turbos with 4" inlets, you can get a smaller alternator from a Hyundai.. Some people say that a 924's alternator will fit as well, but you have to yank the belt pulley and install one from the 944.
Old 06-03-2005 | 06:45 PM
951Porschiste
Yes. That gave me a better access. It's fairly easy to remove. I had replaced the radiator the previous year, so I knew my way around.
Old 06-03-2005 | 06:58 PM
Porsche-O-Phile's Avatar
Porsche-O-Phile
Good job!
Quick Reply: Alternator out......i think i found the problem (pics)
