Smog time - Ca
Old 06-03-2005, 07:46 PM
L8 APEKS
L8 APEKS's Avatar
However, your a/f modifications may render your car a gross polluter on the dyno...
Not if it's running well and it's tuned properly. I could pass my Corrado with fat injectors, a tall cam, a Stage 5 ECU and a 22 psi charger pulley just fine! As a matter of fact, it passed better than the "average" numbers!
Unless that thing is built to make serious power (ie, 400+), it's probably still tame enough to pass emissions with a good cat + O2.
Old 06-03-2005, 10:59 PM
Eyal 951
Eyal 951's Avatar
imma borrow jeff's stock chips hes begging for me to give back real quick to have it done, then Jeff, I'll give em back, unless our "plan" works out!
Doesnt matter what boost is set at.
~Eyal
Old 06-03-2005, 11:23 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Yea, use those for smog - I have a feeling those other ones will only be another possible somethin' that can go wrong! I'll be fine without 'em for a bit, I just want to figure out what's up with my idle. I'll pull the plugs first and check for fouling - might just be old plugs or a rotor or bad ISV or something. I just asked for 'em since it had been bugging me, but now that I'm thinking of it, the car DID idle okay with the Welts in it initially, so I doubt it's just the chips making it run weird.
Old 06-04-2005, 01:42 AM
Danno
Danno's Avatar
No one has failed a smog check with the GURU chips yet, so don't worry about that. Your car has stock flow at idle and partial-throttle, regardless of the max-boost settings. The fuel-mappings I have at those ranges are the same as stock as well. But you've had a tonne of parts on & off the car and there can be a lot of things that could've changed and can throw your emissions out of whack.
Find a "friendly" smog-station. Ask around to see where all the hot-rodders with muscle cars go. Those guys typically need the most help with emissions and they usually have a "friend" in the business...
Old 06-04-2005, 02:20 AM
Eyal 951
Eyal 951's Avatar
Jeff, If you need plug wires, I can get you a great price on Magnacores, let me know...
~Eyal
Old 06-04-2005, 02:46 AM
KuHL 951
Hey Man
KuHL 951's Avatar
Good advice..It might take you longer but it's all about where you take i here in California.
Quick Reply: Smog time - Ca
