Air/Oil separator seals
On an 86' 944 turbo, are the upper and lower seals on the air/oil separator tube the same diameter? I have the Victor Reinz kit and the only red seals that I think are the correct seals are the same diameter (and they fit). My concern is that the old seals appear to be a bit different in size, the lower is slightly larger. The last thing I want to do is remove all the hardware to get back in there if the seals are wrong size and an oil leak ensues.
I replaced mine, and got them at the dealership. I *think* they were different, like the seals you found on your seperator. Maybe someone with a PET can look it up for you.
Will do. I started this project some months ago, there is a thread out there somewhere, "Winter project has begun." I think that is what I titled it. No real progress has been made since Feb. Let me rephrase that, no progress has been made. I am getting the intake manifold, cam gear and shaft cover and water inlet pipe powder coated right now. It should be done any day now. I installed a ported, polished and oringed cyl head and mounted the exhaust pipes (which are heat wrapped) last week. I have sprayed the turbo down pipe and cross over pipe with ceramic paint but have been holding off installing them until I got the air/oil separator seals squared away.
