custom engine prices
Just looking at these engines for the heck of it to see what a ls1 swap would put out and how much it would cost.
There is a $20k jump from 450hp to 560hp. Is this in the parts or where?
http://www.dougrippie.com/drm/engine_conversion.htm
I assume it is similar for Porsche engines since Powerhaus charges $25k for their 3L Turbo engine.
GM is chevy, oldsmobile, pontiac, cadillac, hummer, buick, saturn. They also own saab, vauxhall, opel in the european market.
All from the same parts bin...
Just pick up a used Motor/ECU/Harness/Etc... out of a wrecked low mileage Z06 for $5-10k. That will give you a start at 400hp. There's a world of quality speed parts out there for them incase you want to make the 560hp mark....but for quality expect to pay, no matter who the OEM is.
You better budget in brakes too!
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
-Mark
Originally Posted by Mark944na86
Somehow, I doubt that Saabs and Buicks share the same parts bin. Unless Buicks have gone metric, or Saabs suddenly SAE.
-Mark
-Mark
If you want to be depressed check out crate engine prices.
www.summitracing.com
But don't get too excited. Adapting the tranny, ECU, dash gauges, power steering, AC and so on can easily be more than the initial savings on the engine itself.
A friend of mine put an LT1 into a 928. Thought it would be cheaper and better. Last time I saw him, and drove it, it was more expensive and wasn't behaving like a good system. It was going back to the shop to have a custom torque convertor put in to match the Chevy engine's low-end torque.
Bottom line is that it looks like more cheaper going in. Dropping a 968 engine into an older 944 would be a better approach to power.
