Is there a list of all 968 grounding points?
I want to check all the ground points on the 968. Is there a list of where all these are at?
Thanks,
Harvey
Thanks,
Harvey
Hi,
I'm not aware of a special list, but here is a reasonable list from memory...
1. Drivers side front of car, under hood, behind and below the headlight.
2. Passenger side, under hood, mounted to top of wheel well.
3. Rear of car under carpet. Can't recall quite where but I think it's obvious once you get the carpet up.
4. Under dash - at least one. I haven't cleaned this one - but I've heard if you lay on your back and look up under the steering column you will see it.
5. Battery ground - just follow the wire from the negative side of the battery.
I think I"m missing at least one but this will get you started.
If you do a search on 'grounds' or 'electrical' I suspect you can find something more comprehensive.
Happy Hunting,
Phil
Happy Hunting,
Phil
