Just had the clutch replaced...
Originally Posted by jonnybgood
You really should not be having this much difficulty with a fresh clutch done by a shop. Take it back and they should adjust it or bleed it for you. Don't start doing anything yourself until you give them a chance to correct the problem. If something is screwed on their install they will just say you f'ed it up. Sounds like you have a good shop there and they should take care of you.
I agree with jonnybgood. The clutch should be right and the shop should make it right. However, if you're unsure if there's a problem be you don't have a lot of experience with clutches , ask someone who has driven one for a while to try it. A second opinion, as it were.
