Cooling fan on early 944
Funny stuff,
but before you continue to read, I had a look in the other threads and in clark's garage.
Up to now, my sweety did a lot of crazy stuff, few weeks ago I got the reason why, the engine is not good anymore. But now the electronics start to mess and this in a funny way.
The low speed cooling fan is doing whatever it wants. It turns on, off whenever it likes to. The relay is clicking like wild when I come to these temperatures whese this thing should go on or off. And it loves to come on when the temperature is below 100F. So it draw everything out of my old battery, just by fun, when it turned the whole night and next day until I wondered where this noise is coming from in the garage.
So I guess I have to do something, because waking up every hour and check the baby is not what I want to do. I guess its the thermo switch, but I will check the realy tomorrow, have the tools for this at work, but because the relay clicks so wild, I am wondering if anyone has a spare one.
As far as I see in the shops they only have it for the late 944 and this one is expensive, but I the old one is far less complex. So if anybody can give me a hint it would be nice.
Thomas
Thomas
Pull the fuse. Or negative battery cable. Or both. It'll save the battery. Just don't forget to put it back in before heading out. This is why I personally recommend disconnecting the - battery lead. It's a lot harder to start up and be sitting in stop-go traffic realizing your temps are going through the roof with that disconnected than the fuse.
Anyway, possible failure items include the temp. sensor in the radiator or the relay itself. FWIW I had one with a bad relay that I was able to actually fix by opening it up and cleaning the mechanical contacts. Maybe yours is the same?
If unsure I'd probably R&R the temp. sensor first - it's about $100 cheaper than a new relay.
Thomas has an early model, the fan relay is reasonably cheap - I think I paid $20 at the dealer for the last relay I bought.
The thermofan switch is cheap, too.
I'd order one of each and pull the fuse when every you park it until you get the order.
Hi Steve,
before I wanted to go to the junkyard on Cliton Hwy, the last time I was there I grabbed a handful of relays (but as you see not the right onw). It sits relatively hidden, so hopefully it's still there and not one of those laying around in the diret in and around the wreck.
But I think the relay should be fine, at least it looked o.k. when I opened it. Tomorrow at work I will meassure it.
Best Regards,
Thomas
Best Regards,
Thomas
