WTB: One 7x16 52.3mm Offset Phone Dial
I need to replace one of my front phone dial rims. I purchased some good used phone dials about a year ago and had them all balanced before putting them on. The shop said one was out of spec on one of three specifications. The tech balanced it as best he could but there has always been a slight vibration since installing them.
I haven't done anything and the other day I looked at my ball joints. The drivers side is fine but the passenger side has about a 1/16 of play in it. Since that is where the bad wheel is I presume that the vibration has produced excess wear.
So I am now motivated to get a replacement wheel. I have watched ebay occasionally and they come up once in a while, now I want to correct this so I thought I would try here first.
Thanks Zach, I have called them before. $175 is a bit more than I would expect for a single phone dial.
If I don't get a response from the forum I will be calling the dismantlers.
