Installing crest on aftermarket panel
Just curious. I'm about to buy a fiberglass vented nose panel. It doesnt have a place to put the crest. Any tricks to doing this? Do I need a crest that has screw-on nuts or or the one that goes into a plastic pressure fitting? Maybe I could figure it out if I actually had all the parts infront of me. Thanks!
Either really. Once you have two holes in the panel, and you have the prongs poking through, you could use a star clip, nut, factory clip, but of sticky back plastic....... the list is endless!
