Front Control Arm Removal
My question may sound like I'm a beginner but when i remove the front control arm do i have to remove the front strut. I'm asking b/c when i remove the control arm should i worry about the spring from the strut poping out at me?
Also does anyone have any pictures for references for the removal?
Evan
Evan
No. And no, as long as you don't undo the large nut at the top of the strut. For what purpose are you removing the control arm? Bushings? Ball joint? Also it's a good idea to list, in your signature, or the post the year and model. It helps because there are some minor differnces between them.
Removing the control arm is cake. You don't need to worry about the strut. Just undo the bolt on the crossmember, the 2 bolts that go into the body at the caster block, and the bolt attaching the ball joint to the spindle.
This is after you remove the swaybar, of course.
Good luck.
Good luck.
Good luck.
Good luck.
