DME altitude sensor?
I just put new chips in my car and noticed that nothing is plugged into the altitude/temperature plugs in the DME wireing harness. Is this how it is suppose to be or am I missing something here?
On a related note, the Vitesse chip is much nicer then the autothority chip i had in there!
Which plug are you looking at? If they are 4-6" away from the DME, that's the RCP and IA. The altitude sensor is on the side panel, about 2-feet away from the DME.
I'm looking at the closer one. The only things plugged in down there are the DME, the KLR, and a bypassed alarm box. The car runs well as it is, but I'm just currious if something is missing.
Originally Posted by joes
Isn't there something about putting a resistor in place of the altitude sensor that disables the O2 sensor (ROW) ??
Yep, a 1.8K ohm resistor plugged into the connector will select the 2nd set of maps and disable closed loop
