How to add 20 hp 944 na
Hi there own 2 porsche RoW 944 na 1987 1988 and i have 325is 1994 bmw, i just finsh tune up both 944 and they are nice and handle great but the 325is is more fast fast accelaration, i wondering i have 2000 to put in the cars that mean 1000 each i want to get better performance , , So my question is what things can i buy and add to this cars to get 15 to 20 hp more and they can be same level to 325is , i need really answer from people that know for sure r? people that have make up grades in their cars and got alredy that hp extra !!!!! what i can get !!!!!ofcourse parts that are realible ,and not damage rest of the engine parst over years of used !!!!i thnking all performenace parts exempt turbo the engine or computer managment !!!!that i don want!!!please name brands and stores where you can get that performance parts !!!please if you know respond and i don't want negatve replys there are many of people up there looking for a good advise form you guys //thanks alot guido
It would make sense to remove weight as well, buy a pair of bucket seats and ditch the rear seat, stereo, speakers and put lighter smaller diameter wheels on the car.
www.jmengines.com His cam might get you close you your goal, and leave you enough for exhaust. Otherwise, it takes more then a grand to get 20 hp out of a 944.... Unless you were to raise compression to like 11.0 to 1, and leave everything else alone... that would be under a grand, but you wouldnt really be able to do much with it without engine managment.
"PH 277-14 for 944/928
Best power band 4000-6600 rpm. 900 rpm idle. .474 cam lift (In & Ex) with stock base circles for drop in performance. Uses stock or 944 Turbo valve springs for best results. Motronic chip must have rev limit raised for best results. 14-20 bhp over stock camshaft with non-stock exhaust. Needs stock (37 psi.) fuel system pressure with Motronic at click 1. Tested against all competitors camshafts and proven better. None were comparable."
$650.00
that, with exhaust seems like your best bet.
~Eyal
$650.00
~Eyal
Originally Posted by Jay Gratton
Exhaust is a easy add on part. I have a B&B on my 924S and with a K&N intake I noticed a great change in power! Best wishes - Jay
A good detailing of the car can't hurt to get rid of dirt and grim that has built up over the years. Basically lose some weight.
that weight cant be more then 5 pounds, TOPS, unless you drive through tar pits regularly on your way to work... Though it is a very nice thing to have a clean car all around.
~Eyal
~Eyal
For $1k, best bang for the buck is .... you guessed it... NAWWWZZzzzssss
Easily get a +50hp shot no problem with money left over for refills. The all-motor way of getting +50hp is gonna cost you like $10k.
my car are european i bougt them in gemany last year !!!!!not air conditioning not power stearing !!!!i want something in engine like msd or special plugs wires super coil ?light weight flywheel, and special air filter best min arket for better performenace any help ??????????????i not mechanic just therapist, i don't know if those things will work and waht they do and best brands and company can help!!!!!!!
Air filter, msd and plugs will not give more power. NOS will probably be bad for reliability.
Best way to make your car accelerate faster is to remove weight and keep the engine healty.
