Oil pressure
Oil pressure
My oil pressure gauge spikes immediately to maximum when I start the motor. When I shut the motor off, the needle stays stuck at the maximum reading and when I tap the instrument panel the needle drops back down to 0 bar.
Is it my gauge or my OPRV?
It is mostly likely the oil pressure sending unit. When they go bad, the gauge will stay "pegged" from key on. I'll bet your light at the bottom of the oil pressure gauge works. Replace the sending unit.
