power steering
i think im going to be back to wrestling with my power steering lines at the gear casting thing. i mustve nicked the copper washers up when messing with the stuff. i have some leaks coming from the area, ill check it out better tomorrow.
if i wer wanting to pull clean fluid through the rack, and let the old stuff dump out, which line would i put in the new fluid, and what hose would be my drain? i have 1000 miles on the fluid in the car, but figured after doing the rebuild, i might have some stuff that might get in there and contaminate the seals again.
well it is definitly the one line that i had trouble lining up to the rack.....so i mustve definitly have nicked or completly screwed that copper washer up. does anyone know the size to use? i cant take mine off to match it up....cause i wont be able to drive the car to pick up the part.
