HT leads - compatibility
Simple query - anyone know if HT leads from a 928 (year unknown) will fit a 944S? From a photo, they look pretty similar, but that's not much to go on.
Any advice much appreciated. Cheers.
Kenny
Kenny
apart from there are twice as many......
The 16v and 8v 944's are different. I assume that beings the 928 is a 32v, that they are the same then as a 16v 944. Not certain though...
Cheers Pike. Much appreciated.
BTW, I've factored in the extra leads. I would intend to rotate each set once a week (at the same time as I replace my timing belt - usually every Tuesday night) and that way I should get double life out of them. Now how's that for planning .. eh?
Kenny
Kenny
You replace your timing belt every Tuesday night? You might be over doing it there with the preventative maintenence
Is the car in your avatar real, or is it computer generated? I like the hump in the hood. Is it your car? Have any more pics?
Cheers guys. The avatar is indeed real. DP Motorsport of Germany (check out their website). They do beautiful work (unfortunately the 944 is not mine).
Kenny
Kenny
