Told by a guy at a porsche parts shop that aftermarket motor mounts will do just fine
Old 04-14-2005 | 02:31 AM
Redlyne_mr2's Avatar
Redlyne_mr2
Default Told by a guy at a porsche parts shop that aftermarket motor mounts will do just fine
So i was on the phone today with one of the larger porsche part shops and the guy on the phone told me that the aftermarket motor mounts are just as good as the oem ones. He stated that for every handful of oem mounts he sells , he sells 100 aftermarket ones. I'm wondering if perhaps the aftermarket mounts have improved. Pricing on the oem mounts were $170 each vs $50 each for the aftermarket ones.
Any opinions?
Old 04-14-2005 | 02:34 AM
Jakerx's Avatar
Jakerx
Hitsquad Ninja
aftermarket ones suck. new oem mounts run $120 or so....keep this in mind...it's not something you want to have to do twice. this is one of the things you don't want to skimp on.
Old 04-14-2005 | 02:35 AM
OK944's Avatar
OK944
Any opinions?
I think that statement alone shows why he sells only a handfull oem compared to aftermarket ones.
Old 04-14-2005 | 02:39 AM
Dmitry S.'s Avatar
Dmitry S.
I personally know of 2 people who have had their aftermarket motor mounts fail after only 5000 miles.
Old 04-14-2005 | 03:02 AM
unsigned's Avatar
unsigned
I unknowingly purchased aftermarkets last summer. I've got 2500 on them, and I know they are not doing well. If I had known what I know now about P-cars in general...
Old 04-14-2005 | 06:13 AM
Epic2112's Avatar
Epic2112
Maybe this is because the aftermarket ones keep failing?
Old 04-14-2005 | 08:30 AM
Chris_924s's Avatar
Chris_924s
Nerd Herder
Um.. mechanics make money on labor- not nearly as much on parts. I bet he sells a lot of aftermarket mounts for cost- and then installs them.
Stick with OEM.
Old 04-14-2005 | 09:30 AM
IceShark's Avatar
IceShark
The motor mounts are not exactly a straight forward story. From what I understand there was an Asian manufacturer that came to SEMA some years ago and one of the items they were selling were the motor mounts. These mounts turned out to be junk, failed quickly and were most likely the genesis of the bad aftermarket motor mount stories.
Some suppliers are selling motor mounts called aftermarket for $50 each. If you look at them they are the same upgraded style made by Meyle Products of Germany for Porsche. The only apparent difference between them and the ones that come in the Porsche box is that Meyle has ground off the Porsche trademark cast into the rubber portion of the mount and they may have also hit the Porsche part number cast into the rubber.
That is the only difference you can visually see. The only real question is Meyle dropping manufacturing quality on the mounts they take the Porsche trademark off of? I would doubt it so I think it is worth it to try the "aftermarket" as long as they come in the Meyle box.
Old 04-14-2005 | 11:28 AM
Red1's Avatar
Red1
Pretty much sums it up. For the time/PITA involved, it's worth it to me (and apparently others) to just do it right the first time. Nothing's worse than redoing jobs you did last year.
Old 04-14-2005 | 11:31 AM
Stuttgart 944's Avatar
Stuttgart 944
how long on estimate do oem motor mounts last? I just got mine done about a month ago (300miles ago)?
AznDrgn's Avatar
AznDrgn
I've heard good things about the ones the Zims sells. Guess I'll find out once I install them.
Old 04-14-2005 | 11:52 AM
Redlyne_mr2
Thats who the shop was, I wonder if those are the Meyle ones iceshark was talking about. So many different opinions on here.
Old 04-14-2005 | 12:04 PM
IceShark's Avatar
IceShark
Yeah, Zims and German Parts & Restoration in CA sell the Meyle mounts with the P trademark ground off. I think Paragon does, too, but I have never seen theirs in person.
Manning's Avatar
Manning
The aftermarkets I installed on my car failed after about a year. The OE I have on there now are still going strong after about 2 so far.
Old 04-14-2005 | 12:05 PM
mbonner's Avatar
mbonner
I got mine from Ian's. They are made in Germany and the shop which installed them said they look exactly like the Porshe ones.
So far, so good, anyway.
Mike
Quick Reply: Told by a guy at a porsche parts shop that aftermarket motor mounts will do just fine
