Wheel bearings, huge shop prices
Well looks like I'll be doing these myself.. guy wanted like $600 for the rear and $300 for the front.. I can buy all the parts I need for $138
Not looking forward to it, but it will be worth it. Has anyone else done bearings and noticed a huge reduction in noise?
mine weren't that bad, so i didn't notice much difference in sound. fronts are pretty easy, rears a little more work, i think paragon has a writeup for both if you need it.
New bearings do wonders. The fronts are cake - removing the hub doesn't require much effort and the whole job can be done in under 2 hours. The rears are supposed to be a bit difficult - I know some able mehanics who took their cars to the shop for the rear bearing to avoid the hassle.
The difficulty of the rear bearings is a bit overrated. Like any job, having the proper tools makes all the difference.
Tools I used/needed:
impact wrench
bearing puller designed for that bearing
two-arm puller (to get the old inner bearing race off the stub axle)
slide hammer
32mm impact socket
BIG torque wrench (axle nut is torqued to 500Nm)
propane torch
+ everything you'd normally need to remove the CV joints
Most of us don't have all of that laying around. Neither did I. I borrowed what I needed and had it done in an easy afternoon. It was a much easier job than what I had been led to believe.
Did the car feel better? Night and day. My rears were absolutely shot. Rolls smooth as butter now.
impact wrench
slide hammer
32mm impact socket
propane torch
Done With Sidepatch
Originally Posted by Mike C.
Don't forget to heat the front hubs before installing new bearing races... (steel races in aluminum hub)
