944 Kevlar™ Timing belts
Old 04-14-2005, 08:59 PM
  #46
Mike C.
Mike C.'s Avatar
Experiment away guys. It's only the timing belt... Oops. Who's liable?
Old 04-14-2005, 10:18 PM
  #47
Peckster
Peckster's Avatar
Who's the manufacturer?
Old 04-16-2005, 05:12 PM
  #48
Swagger93
Swagger93's Avatar
Originally Posted by Bill
Moon hit the nail on the head.
There are several reasons the Porsche engineers used a belt over say gear drive or chain drive. Belts are quieter. Belts are cheaper. But I believe the main reason is, aluminum expands at twice the rate of cast iron. As the 944 engine heat up, it grows and the belt needs to grow or stretch with it. Especially since there is no automatic belt tensioner on these engines. I have taken readings on a hot engine belt with the 9201 gauge, and the belts are over double the cold tension. If a kevlar belt does not stretch, will the tension become way too tight as the engine grows? Or lower the tension and will it be too loose when cold?
Prove to me that kevlar will perform with the engine's expansion rate, and I would be interested.
Belts are quieter? Explain the loud whine coming from the front of about half of 944s despite good rollers and proper tension. My saab exhibits almost NO noise from the timing chain, the head is aluminum, and the chain is still the OEM at 194,000 miles. The fact that there is no oil-fed tensioner in the 944 is beyond me.
Even if belts were substantially quieter, I don't understand the rationale behind that argument. The 944 engine is a relatively loud engine as is, not to mention it is in a sports car, so I can't see a small amount of noise from a chain posing a problem.
I was recently involved in a headgasket project on a 1994 Sundance....the timing belt was twice the width of the 944s--it is a 2.0 liter and it wasn't even an interference engine.
I stand by the idea that the timing belt arrangement in the 944 has inherent flaws that either weren't intially seen or shrugged off as a regular interval item to cut costs by engineers designing the car.
Old 04-16-2005, 07:34 PM
  #49
Serge944
Serge944's Avatar
Originally Posted by fast924S
The trick is not to find the best T-belt, The trick is making some kinda auto tensioner for the 944/951. This way the belt will always be in spec. Now if some one where to make a auto tensioner kit that had a better belt, Even if it only doubled the maintenance periods on the belt then I would go for it
I don't think tension is a problem at all. The majority of times the tension doesn't need to be changed at 15k.
Rollers that last at least 100k would be nice. Belts usually get sheared because the bearings freeze up. A 60-100k mile belt change would be awesome.
Old 04-16-2005, 07:58 PM
  #50
my84-944
my84-944's Avatar
I think it may have been an issue in weight more than noise. I also agree that the 944 should have gotten a wider belt. You would think that an interference enging there would either be chain or a bigger belt right? I would expect Porsche to have a little better design, even in the late 70's and early 80's. But then again look at Mazda and Honda. I do not know why the final production 944 did not get a tensioner or a wider, stronger belt. What I do know is that mine broke and I am NEVER wanting to go through this again, and I have not even started repairs yet.
Old 04-16-2005, 09:27 PM
  #51
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
hey guys looking at the tensions I was thinking about something. A kevlar timing belt would never expand when exposed to the heat conditions the common rubber timing belt goes through. I personally would love to have a Kevlar belt too! Just still afraid of even pushing it past 60,000.
  #52
dan_c
dan_c's Avatar
I seem to remember my mechanic telling me that 994S engines have a self adjusting tensioner...I am not a wrencher so I can't speak from experience or much of anything...
Old 04-16-2005, 10:03 PM
  #53
Serge944
Serge944's Avatar
All 944 87 and after had a spring tensioner, except the 968, which had a hydraulic unit. They are all less reliable than the original eccentric.
Old 04-16-2005, 10:27 PM
  #54
NZ951
NZ951's Avatar
I think I will just keep servicing my T belt every 30,000 or so and that will suit me. I dont want to push the life of any T belt I put in there.
Old 04-16-2005, 11:32 PM
  #55
GOSANE
GOSANE's Avatar
Count me in.
Old 04-17-2005, 04:15 AM
  #56
Dmitry S.
Dmitry S.'s Avatar
Matter of opinion. The spring tensioner, if used properly will ALWAYS tension the belt to 4.0 on the P9201. The 968 tensioner requires no adjustment ever, and is simply a remove/replace belt job. With either of these systems, it just makes it more difficult to make a mistake.
Old 04-17-2005, 10:20 PM
  #57
eman930
eman930's Avatar
I like the spring tensioner, but I would love a hydrolic one
Quick Reply: 944 Kevlar™ Timing belts
