Idle Speed Valve INSTALL
Old 04-12-2005 | 08:47 PM
chitown928s4's Avatar
chitown928s4
Default Idle Speed Valve INSTALL
Whats needed to Install the Idle Speed Valve. I know I got take the manifold off but thats about it. How long will it take and can I do myself. Tips, Tricks Info appreciated.
Old 04-12-2005 | 11:07 PM
PeteL's Avatar
PeteL
Got Nothin'
Pretty straight forward. You will need to have new intake gaskets and probably a few injector rebuild kits. Biggest danger is a fuel leak after removing and reinstalling the injectors. Other than that it is really a piece of cake.
Old 04-13-2005 | 12:56 AM
fezz's Avatar
fezz
plan on replacing vaccum hose and line under the intake that is old and cracking. while your in there kind of stuff. If you have an N/A dont forget to disconnect the little hose under the intake before removing the intake manifold. See clarks-garage write-up for more info.
Old 04-17-2005 | 03:40 AM
chitown928s4
UPDATE!!! Its done evrything went real smoooth. Thanks god for family member who's a machanic. Thanks to George from 944Ecology for the used ISV. The old one was full of soot..so I guess that sucker should be cleaned every so often.
Old 04-17-2005 | 05:31 AM
Eyal 951's Avatar
Eyal 951
full of soot? you may want to look into your car and find out why its full of soot.
~Eyal
Quick Reply: Idle Speed Valve INSTALL
