late throttle body on early car
Awhile back I installed a late throttle body on an early car. Can't find part numbers to compare but I know that the TPS switch on it is the same as an early. Car runs fine excpet for loud fuel pump, im wondering if this may be the source of my problem.
Only difference I can see in the 2 is a different head on the idle adjustment screw. Thanks.
Check the vacuum to the FPS and FPD. A fuel line over pressure problem causes a lot of fuel pump noise.
Throttle body had nothing to do with the fuel pump. Neither does the TPS setting.
83 944 = It's NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts
and/or cam chain and tensioner?
The 83
The 83
