wich is best inatke system today for 944!!!!!!!
i have a 944na 1987 european 163 hps i will like get a good air system??wich work best in this car !!!! i see some in ebay made of type standard grade reticulated foam.they said ((((((it works much better than the other K&N conicals that get Heatsoak. You'll get way more power with this kit. A Cotton/ metal filter will help you lose power. Check out the web.. Look up what the Brit's and Germans use on there rides)))it is true , somebody know wich is the best value and best performance !!!!!i want get more hp witout **** engine or reduce life !!money not matter !!!thanks guido
guido, first of all, welcome to rennlist, where are you from? best air system is the stock, no real upgrades to be made here, sorry. do a search, this topic has been beaten to DEATH!
so nobody thinks there is a better option that the stock air filter!!!!!!!!i will like to think there is a air cone intake better thatn other that make car breath better and ru better ???guido
Trust me I am getting more air flow, and nice cool air from my set-up....The factory air inlet thru the fender frame is still being used to feed air to the box....Along with a few more places to draw cooler air from using scoops.....
DAmian
DAmian
