Power steering hose
This is an updated piece direct from Porsche. Just get the new OEM one from the dealer. Its not all that expensive, and a lot less trouble than trying to make something else fit.
Isn't the one from the reservoir to the pump just a standard hose, nothing special about it? That hose is not under pressure and doesn't have the flare like the other hose if i remember correctly. I may have my hoses reversed but i know one of them is not under pressure and can easily be replaced with one from the auto parts store.
-Erich
-Erich
I'm thinking that the top end was larger. Like Travis said, it shouldn't be too bad from the dealer. Also, the routing of this formed, fitted hose is a little iffy, standard hose may rub the water pump or the belts and end up getting cut. Better off with the real deal. Check Paragon Products.
-Erich
-Erich
I replaced the hose from the cooler (near the headlight) to the resevoir with a piece of high pressure oil hose. Been fine for a few years. Any other hoses I'd get the correct part.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
discovered a leak in my high pressure ps hose this morning....... where is the best place to get a new one ?
i think they may cost over $ 250 at the dealer.
okay GermanAutoParts to the rescue again -- $ 159.00
Whats the deal with posts like this lately. I have been seeing it more and more.
It is almost completely unrelated (different hose), which is fine in itself but it brings up a post from 5+ years ago?
I blame the search button. Having the quick search bring up posts by relevance rather than date order is just dumb.
