What's wrong with your car?
Old 03-28-2005 | 07:23 PM
  #46
black944 turbo's Avatar
black944 turbo
1)Don't get to drive it enough
2)Smokes on startup on occasion
3)Running rich!!!!
But it is fun and plenty fast for me.
Old 03-28-2005 | 07:30 PM
  #47
theedge's Avatar
theedge
The best bit is on the floor
The list of upgrades and parts getting replaced is longer than my..... Well almost as long as my arm. The stack of bills is getting pretty high too
Old 03-28-2005 | 09:15 PM
  #48
inactiveuser92616's Avatar
inactiveuser92616
still not satisfied with the front wheel bearings after adjustment; probably need to replace them but have no time right now
left rear tire keeps rubbing the fender over hard bumps, need to check if it is the proper offset (was replaced)
Fuel economy seems to be going down
Old 03-28-2005 | 09:24 PM
  #49
Dmitry S.'s Avatar
Dmitry S.
1. Accident damage in the front - hopefully fixed within 4-6 weeks
2. Clutch center gone - also hopefully fixed within 4-6 weeks
3. Cracked windshield
4. Warped front rotors
5. Vacuum leak somewhere
6. Oil leak at valve cover gasket, and front seal.
7. Needs new front tires
8. PS belt a bit noisy.
Old 03-28-2005 | 10:07 PM
  #50
Chris_924s's Avatar
Chris_924s
Nerd Herder
Originally Posted by Highway T
Well if we are getting all confessional:
1) Crunchy sunroof gears.
2) Steering pulls to the left.
3) Possible slow fuel leak at right rear. Gulp.....
4) Covered in cat footprints!
Hey Chris, hows it going!! Hows the UK treating you?
Ok. Got time?
Before this weekend:
replace interior wire loom- specifically splice in new headlight switch pigtails
Fix headlights -FINALLY!!
Rebuild all window switches - again,
reset odo guage. again.
Replace fuel rail. again.
Replace fuel lines.
install new vents for AC.
Fix washer stalk.
Retorque CV's
Upcoming in by April 15:
Fix Cruise control (resolder brain)
Install new Oil Pressure lamp- PITA.
Replace AT lines.
replace rear TT bearing.
Flush and fill AT.
Rebuild AT and put in new filters and gaskets
Full tune up (Plugs/wires/cap/rotor)
Pass e-check :
Next few months:
Weld on rear quarter.
Dolly out dent in rear.
Install 931 Splash panels.
Next few years:
New Paint.
New Interior
Old 03-28-2005 | 11:02 PM
  #51
nine-44's Avatar
nine-44
86 NA
Rack-done
tires-done with one leaker(dammit)
clutch-saving pennies
paintwork and repair body damage
85.5 NA-Tammy's
wheel bearings in the front-parts on the way
trans swap
fix a little body damage
front speakers and mount radio
strap down that friggin sliding *** floor mat
wheel swap
84 NA-mom's
due for oil change
rust repair
odo broken
put stock airbox back in
find seats-tan
a good detailing
86 951-dad's
fix turbo coolant pump
figure out intermittent starter no-crank
fix a few dents
needs a good detail job
paint sunroof
odo broken
954
need more steam
odo broken
install 968 oil cooler and duct work
finish 949 project
Quick Reply: What's wrong with your car?
