Cookie cutter wheel hub dimension
I'm having some wheel adapters made and need to know the diameter of the center hole on a cookie cutter wheel (ex-944).
Using my plastic vernier caliper (Harbor Freight freebie), the hole in the wheel looks like somewhere around 2.75" or 71mm. I suspect the whole hubcentric idea, though, is to be precise. Don't have a whole 944 here - what I really need is the diameter of the 944 hub where it enters the wheel.
A book answer or online reference would be most appreciated.
M D "Doc" Nugent
M D "Doc" Nugent
Nerd Herder
Try "Racer-X" or www.clarks-garage. (Search for Danno's webpage here on good ol' Rennlist)
and welcome to Rennlist!
If you need more info post back.
