warm idle stalling - help
Hi, I'm looking for some help with my 86' 944. When warm it stalls after idling for more than about 30 seconds.
I have replaced the fuel pressure regulator. I have cleaned the idle stabilizer valve (I also have a clean used ISV - does not help to put it in instead). All the vacuum lines look good. The air box seems to operate o.k. After it stalls I can feel the ISV vibrating. It's a little hard to start after it stalls. When cold it runs perfictly fine. As it warms up I start to get a few misses at idle. After it's warms though it's very sluggish of the line and just dies
sounds like a bad temp sender, the one on the block, the one with the bosch style plug. The manual describes a bad temp sender as your exact symptoms. There's an ohm test for cold, warming and hot. I don't have the specs in front of me sorry. Sounds like the issue tho. Double check to see that it is plugged in and tight.
